Author Topic: 126 Bis gearbox mounts. Dimensions needed.  (Read 1595 times)
« on: September 24, 2019, 10:18:12 AM »
Following up on a few posts from some other forum members here, does anyone have a gearbox mount and can measure the following:
the diameter of the bush (the pressed in metal ring surround the rubber)
The thickness of the bush.
There must be something out there similar!
126blackbird
Re: 126 Bis gearbox mounts. Dimensions needed.
« Reply #1 on: September 25, 2019, 10:46:42 AM »
There was a post on one of the forum's that said a BMW bush will fit, the hole for the gearbox stud is a little bit larger so you have to modify this or fit a sleeve, I did buy a pair of these but as yet not tried to fit them. I'm not at home for a couple of day but will see if I can find the part number when I return
