Author Topic: Brakes pulling on one side  (Read 1782 times)
Neville Minuti
« on: August 06, 2019, 12:10:02 PM »
Recently I changed the following:
Master cylinder
Shoes for the 4 wheels
All Wheel cylinders - front larger than the rear
Brake rubber hydraulic pipes of 4 wheels.
Now I have the car pulling on one side, i.e. the front right wheel and rear left wheel are braking well.
What could the problem be?
Thanks,
Neville
Re: Brakes pulling on one side
« Reply #1 on: August 06, 2019, 01:06:08 PM »
The self adjusters on the shoes may be stuck and might not have adjusted yet, on a clear road stamp on the brake pedal, do some emergency stops forward and reverse see if it improves
« Reply #2 on: August 06, 2019, 04:32:55 PM »
It seems that only one hydraulic circuit is working properly then. As far as i Know there are 2 hydraulic circuits that operate the brakes - one front and one rear wheel, independently. Something must be up with one of the circuits, ie. a clogged pipe or air in the pipes. try bleeding the brakes again and see if that helps….
Neville Minuti
« Reply #3 on: August 07, 2019, 04:14:36 PM »
Thanks everyone for the feedback
