Author Topic: lowering for free  (Read 8954 times)
lowering for free
« on: July 16, 2006, 03:39:02 PM »
just found another lowering tip,the alloy blocks that mount the front spring can be shaved of 8mm that gives me 38mm at the front.......and for zero £'ss.......... :cool:
slater
    • http://www.retro-rides.com
lowering for free
« Reply #1 on: July 18, 2006, 08:45:57 PM »
You can take off more then 8mm if you are brave too! :lol:
lowering for free
« Reply #2 on: July 19, 2006, 06:14:09 PM »
i know......i was just being a good boy for a change................... :lol:
and,you have to be carefull of the center bolt not hitting the body work.
good start tho for low buck tuning
lowering for free
« Reply #3 on: August 29, 2006, 06:18:26 PM »
ok,got bored today,(still waiting for brake bits),so,beer in hand ventured forth to remove more material........13mm lower now...... :cool:....................getting very bored,sand blasted and painted them as well,and the front spring.......................
so,spring and blocks now add up to 43mm lower....................
Tomasz
lowering for free
« Reply #4 on: August 30, 2006, 09:17:51 AM »
Do you have any more pics of you car dave, it would be great to see how it looks lowered.
valenti.no
lowering for free
« Reply #5 on: August 30, 2006, 08:34:27 PM »
lowering is easy.. rear spring you can cut (e.g. -1 coil, I have -1,5 coil) front spring ( I mean that thing between wheels :wink: ) You have to remove all leafs... than you take hummer - your friend schould stay in the middle of the leaf (one of that removed) and you have to bang on potholes (I don't know how to say it in English)on both sides.. My front spring stay 4cm above the ground and I have 6 leafs.. It is good thing to change front shock absorbers to rear ones (rear shock absorbers are harder and shorter) In Poland we have blacksmiths to tune ours suspentions :wink:
http://img101.imageshack.us/my.php?image=dscf0993mediumwt0.jpg
http://img87.imageshack.us/my.php?image=dscf0994mediumwp0.jpg
pics on car :wink:
Tomasz
lowering for free
« Reply #6 on: August 31, 2006, 09:49:58 AM »
I have 12" alloys and im not sure if it would look as good lowered on 12's but i think it is probably a good next step for me as it would improve handling greatly.
What do you guys think?
valenti.no
lowering for free
« Reply #7 on: August 31, 2006, 10:00:48 AM »
lowered 126s always look good!! what size of 12 tires you have??
lowered "maluch" on 12' http://www.terytorium126p.fora.pl/viewtopic.php?t=173&postdays=0&postorder=asc&start=45
Tomasz
lowering for free
« Reply #8 on: August 31, 2006, 04:26:19 PM »
That one is really nice too!  Think the tires are 165/70.  Your wheels are 13" right?
lowering for free
« Reply #9 on: August 31, 2006, 06:32:27 PM »
hi! love your car!,and i agree,tuning is techinical work,not spoilers etc....the shocker tip is a good one! as for the lowered suspension,i have the reverse eye front spring and cut and harder rear coils,with 30% uprated shocks already....i was just looking for some more!  :cool:
your english is very good,and it sounds like you will be adding greatly to the knowledge base on this site......its those kind of tips,(the rear shocker one) that are needed,anyone can buy the other tuning bits ''off the shelf'',but little snips of info like that are very important,i really rate tips like that myself.
dave
valenti.no
lowering for free
« Reply #10 on: August 31, 2006, 09:22:13 PM »
:arrow: Tomasz - my wheels are 13 from abarth (atiwe for abarth) fiat uno 6j13 and tires 175/50/13- very wide  :cool:
 :arrow: 126dave - I know a lot of tips for 126. In Poland we have saying :" Polak potrafi" it means that in Poland we can do everything :wink:  For example we can make hard shock absorbers- you have to pour gear box oil to the stock oil shock absorber  (60% gear box oil- 40% absorber oil) it really works!! If you are lowering suspiention you must remember to cut these rubber "piramids" -2 cm in front 1or 2 bulbs on rear spring...
I had to bang (I don't know how to say it in English) that part of sheet metal...... hmmmmmmm I will show you a picture :wink:
http://img434.imageshack.us/my.php?image=rantyha5.jpg
Wojtek (Adalbert)
lowering for free
« Reply #11 on: August 31, 2006, 09:51:05 PM »
hi yes,we call that 'rolling the arch'.....needed for clearence of wide wheels.
i have not trimmed my pyrimeds (bumpstops)...i find this helps, with hard cornering its good to get the outside wheel on the bumpstop,that stops the car lifting and tucking in the inside and outside rear wheel (deadly)....i find this suits my driving style..... :twisted: i can go as hard around a sharp corner as i want,all i get is wheelspin when the car is at its limit...........
valenti.no
lowering for free
« Reply #12 on: September 03, 2006, 05:06:39 PM »
Could you make some pics of that bumpstops on car of course :wink: under your car.. I have some problems on pothols... On full turn tire sometimes wipe on that arch on top... I have to roll it better and I think It is a good idea to have not trimmed bumpstops or cut them not so much as I have now (on flat road about 8mm between "pyramides" to front spring... I have very looooooooooooooow car
http://img304.imageshack.us/my.php?image=dscf0925medium6di.jpg
http://img304.imageshack.us/my.php?image=dscf0926medium2ft.jpg
lowering for free
« Reply #13 on: September 03, 2006, 05:31:09 PM »
hi from jersey,i have around 5mm at the front spring bumpstop (un cut,but jersey roads are very smooth!) ......i will take some pics soon,of the whole car as well,my wheels are only 5 1/2j x 13'' with 165-55 tyres.........i am using rear wheel drive pattern wheels(cromodora cd 11),so the off set is just about right for the size,as i have posted else where,i also have 10mm negative camber at the front,this gives more clearence in the wheel arch for the wider wheels.
im also running at the moment with nuetral toe in/out,this is giving a very good feeling to the steering!!!.
with only 30ish bhp,i am not going to go any wider with the tyres,i want to keep the rolling resistance as low as possible.
dave
slammed 66
lowering for free
« Reply #14 on: September 07, 2006, 12:20:20 AM »
How low is your car sitting at the front now Dave?
Any pics mate?
