Author Topic: Low compression when cold, ok when hot  (Read 2560 times)
nick7nick7
« on: November 22, 2018, 07:03:09 PM »
I have a 90 Bis.
Its impossible to start from cold, due to low compression on cyl1 circa 12psi. However, when warm (20c+) the compression measures 122 psi. cyl2 is constant at 126psi
Any suggestions what or how to fix it?
I think it could be piston rings. But im not mechanic.
Re: Low compression when cold, ok when hot
« Reply #1 on: November 22, 2018, 07:33:49 PM »
Hi nick, BIS engines LOVE eating head gaskets. I've taken heads off and the old gasket just falls apart between my fingers so I would be suspecting that this has happened to yours, although not as drastic as the one I last did. I think the reason it regains its compression is because as the engine warms up all the components expand due to the heat and it effectively re-seals itself so perhaps a pin hole sized hole has appeared. There are fluids you can use like K-Seal which works like radweld and seals the hole after you've emptied it into your water system but to be honest if a jobs worth doing it's worth doing right so I would opt for getting the head gasket done. It's actually rather easy and well within the relms of a diy-er to do
nick7nick7
« Reply #2 on: November 30, 2018, 09:42:25 PM »
Cheers for that gadge. I recently had the head skinned and pressure treated.
Not done a hundred miles since.
Do you have any idea where I can get one of the copper ones? Or is it a case of making my own?
Sent from my S60 using Tapatalk
nick7nick7
« Reply #4 on: December 01, 2018, 07:29:53 AM »
Cheers matey, not heard of that first shop.
Will it still eat away at the copper ones like it does with the cork version I got last time?
Xylaquin
« Reply #5 on: December 01, 2018, 10:05:01 AM »
Hopefully not, though if your head gasket was made of cork I have a theory what your problem has been  :o
nick7nick7
« Reply #6 on: December 01, 2018, 10:08:01 AM »
Hopefully I'll get it striped tomorrow and see.
Dependant on the weather.
« Reply #7 on: December 01, 2018, 08:39:43 PM »
Are you thinking of rocker gasket or head gasket ??
nick7nick7
« Reply #8 on: December 01, 2018, 08:55:17 PM »
Head gasket
