Author Topic: What alloys fit?  (Read 11164 times)
Captain Hazzard
What alloys fit?
« on: July 09, 2006, 09:57:55 PM »
Are there any cars out there whose alloys I could pinch and bolt straight onto my 126? Or is that asking too much?!!!
How do you go about fitting alloys then? Is it all about adaptors and generally not done?
I only wanted to be 16... and free
richard
have a scan
« Reply #1 on: July 09, 2006, 10:05:29 PM »
Captain Hazzard
What alloys fit?
« Reply #2 on: July 09, 2006, 10:22:32 PM »
Some good reading there, cheers.
What alloys fit?
« Reply #3 on: July 09, 2006, 10:54:40 PM »
richard is well on the ball tonight!
beat me to it everytime! :D:D gives my fingers a rest from typing
cinquecento or fiat x1/9 alloys are always good to put on. dont chuck the orginals away though!!!!
regards
Captain Hazzard
What alloys fit?
« Reply #4 on: July 10, 2006, 10:26:47 PM »
I'll keep a look out for cinquecento wheels, do they just bolt straight on then? Can't be too hard to find a set of them can it?
Bruce
What alloys fit?
« Reply #5 on: July 12, 2006, 01:44:46 AM »
I got cinquecento one on my Bis (click the picture for a bigger image)
they go straight on with no probs, event he standard bolts work, only trouble is the tyres are quite pricy because they are a rare size only made by a perrelli and a korean firm, even they cost over 150 a set, but they do look pretty good
What alloys fit?
« Reply #6 on: July 12, 2006, 06:37:50 AM »
Original 126 alloys are still nice. only 12'' not 13'' like most people want but on a lowered care look ok. getting a bit hard to find.
I have them on mine. will post a picture leter today.
Tomasz
What alloys fit?
« Reply #7 on: August 11, 2006, 10:17:42 PM »
i have 12" kn minilite style alloys which i bought from midland wheels (check out their site).  They fit straight on and are the only minilite style ones that do except those abarth ones you can get but they are more expensive. They are 5 wide and i think they look pretty good, i will post some pictures when i have some better ones.  Having trouble getting locking nuts though 'cause the ones i bought off ebay had the wrong thread as did the bolts midland wheels supplied!
What alloys fit?
« Reply #8 on: August 12, 2006, 08:59:53 AM »
i prefer 12'' rims on the 126's.(lowers the gearing)..if i could find some 12'' cromos id fit them,still thinking of minilites for mine as well.
probably why the bis was fitted with 13''s and lower final drive +more torquey motor=higher cruising speed= name of bis='touring,or scenic' as used on french tourist routes........jeezz,im off on one again......... :lol:
What alloys fit?
« Reply #9 on: August 12, 2006, 03:31:48 PM »
I have 13" magnesium wheels on mine shod with 175/50/13's .. mini sized tyres- needs lowering tho could loose a tramp under those arches.....
What alloys fit?
« Reply #10 on: August 13, 2006, 08:34:54 AM »
thats coming on stuey!!!...........i've been taking advantage of my 'down time'(waiting to sort brakes) by getting shot of my side bumper holes as well.
heres a tip on the lowering/tyres touching problem,if you do the neg camber trick i did,(10mm in redrilled top link),you gain a lot of clearence around the front lower wing lip,i reckon i could go up a size now on tyres,not going too tho,i want to keep my rolling resistance as low as possible.
that might help you when you do lower it.
What alloys fit?
« Reply #11 on: August 14, 2006, 07:21:01 PM »
Hi Dave, i think i may have to do this mod, i have a set of 5 1/2" tsw wheels with 165x60x13 but i'm not sure how to do it, do i have to weld plates on the inner top suspension arm and re-drill them 10mm in from there original hole
Pete
What alloys fit?
« Reply #12 on: August 14, 2006, 09:20:09 PM »
hi pedro,all you have to do is fill the existing holes,i used some bolt heads that pressed in,then welded and ground down,then you make a little piece of flat stock to fit in the area you want to redrill,go as far in as you can,while still allowing enough flat area for the nut and bolt head to sit,mark it,and use as template for all 4 holes,i went to 10mm.dead easy.
renew your bushes at the same time......
im going to take some shims out next,3 from each stud,that still leaves the odd ones to correct body shell inacuracies
What alloys fit?
« Reply #13 on: August 14, 2006, 09:38:58 PM »
Thanks Dave for the info i've just aquired two spare top arms so i'll have ago at that in a few weeks time when i've got the cylinder head back on and the body ready for spraying,  did you fit the standard bushes or the poly bushes a mate of mine has a lathe, and you can buy the special poly bars for suspension bushing, i fitted them to my spitfire (not the plane haha) and it made a big difference to the handling
Pete.
What alloys fit?
« Reply #14 on: August 14, 2006, 09:56:08 PM »
hi pete,i fitted standard ones,they are metal sheathed,and are a press fit in the top link.......im not sure if poly ones could be made to fit?
i would be very interested in poly bushes for mine tho,be nice to replace all the (new) but mushy rubbers.lots of play in the front end,even with new bits
im going to look into modding my spare top links to get another 10mm,that will need some proper engineering tho.
i have been checking all the ''tuning'' sites,nothing is listed,for bushes or neg camber top links..odd really,the turn in on mine is amazing with just that 10mm.............i cant wait to really try it hard on ''the power'' thro some nice bumpy corners
