Author Topic: Innocenti 126  (Read 5246 times)
Bar Vitelli
Innocenti 126
« on: February 18, 2018, 08:52:19 AM »
Would these wheels fit a Fiat 126 aircooled car either early model or later edition?
https://www.ebay.it/itm/MINI-INNOCENTI-MINI-DE-TOMASO-RARI-CERCHI-CMR-5x12-OLD-STOCK/122954710751?hash=item1ca0abfedf:g:kawAAOSwI~taeg-t
If not, what modifications would be required to make them work?
Every cloud has one...
Re: Innocenti 126
« Reply #1 on: February 18, 2018, 08:58:18 AM »
They would only fit the later 98pcd wheels with wobble bolts so not ideal  :)
Re: Innocenti 126
« Reply #2 on: February 18, 2018, 09:00:41 AM »
I would have thought not as I thought the mini innocenti was based on the BMC/Leyand mini which I'm sure is an imperial PDC size like 4x101. That said though if you look at a classic mini wheel the studs look further apart than the ones in the innocenti wheels so maybe they were metric for the Italian market
drcdb15
Re: Innocenti 126
« Reply #3 on: February 18, 2018, 10:59:18 PM »
101.5 apparently http://www.fitmentguide.co.uk/mg-rover-mini-wheel-fitment#one
Re: Innocenti 126
« Reply #4 on: February 19, 2018, 06:19:53 AM »
Ooooh I was close :P
Allan
Re: Innocenti 126
« Reply #5 on: March 27, 2018, 11:18:58 PM »
The wobble bolts I have seen will not cover the 3.5mm difference here.
derekscoopers
Re: Innocenti 126
« Reply #6 on: July 24, 2018, 08:37:37 PM »
Its a straightfoward job, get them offset drilled at TT Tools in Essex and use wobbly tuner bolts they have a smaller 60 degree taper .
derekscoopers
Re: Innocenti 126
« Reply #7 on: July 24, 2018, 08:41:33 PM »
Mine are mini wheels and they sorted these out no problem, fit perfect, remember to get the centre bore altered whilst your having the boilt holes done,
pietschokkenbroek
Re: Innocenti 126
« Reply #8 on: July 26, 2018, 11:21:00 AM »
nice!  8)
