Author Topic: Gear stick adjustment  (Read 1614 times)
polenglish126
« on: November 14, 2017, 09:25:40 PM »
I pulled off the rubber to the gearstick today and gave the three bearings inside a good greasing and sprayed the spring too It seemed to actually help is there any adjustments I can make and how do I get to them. I keep on hearing too there should be 15mm of play in the clutch cable from the gearbox from when it is pressed down is this true?Cheers Marc.
