Author Topic: Best electronic ignition?  (Read 4127 times)
DeVilleChris
    • Club 126 UK
« on: November 05, 2017, 09:35:10 PM »
What's out there? Fed up of not being able to drive my 126.
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
Jake.Pidduck
Re: Best electronic ignition?
« Reply #1 on: November 07, 2017, 07:20:08 AM »
An electronic one
1976 Fiat 126 "OPD"
« Reply #2 on: November 08, 2017, 12:00:34 AM »
I have the 123 system fitted and it works really well, a tad expensive, not had any problems over the last 5-6 years. Others on this site have used successfully a system sold on eBay which seems easier to fit and is only about £40 ish the last time I looked.
mintex
« Reply #3 on: November 08, 2017, 08:34:06 PM »
I made an AccuSpark unit fit my bis and that works ok with no problems  ;)
Dave
« Reply #4 on: November 09, 2017, 03:14:21 PM »
If you are happy with the price of 123 ignition  - buy it.
It is very well made and I have heard the customer support is excellent.
This unit replaces all mechanical components with an electronic system.
The accuspark is much cheaper but uses the original bob weights.
The timing is mechanical but the delivery of the spark is electronic.
You can also move onto a modern coil as well for a bit more reliability.
corty
« Reply #5 on: April 29, 2018, 06:15:30 PM »
i too am running accuspark
its interesting to set up when you have never had the car running
i found a BIS will run with 60Deg of advance! all be it a bit lumpy!
ive now set mine to 10 deg ,  with the vac advance removed - need to test the vac advance at a later date to make sure im getting another +8 deg (18 total at 3000rpm)
