Author Topic: Not sure what this is.  (Read 3730 times)
« on: October 04, 2017, 04:38:43 PM »
I was checking the hoses around the carb area to make sure none of the hoses were loose. One of the hoses below the carb connected to a gizmo (solenoid?). From this, a hose connect back to the carb. There is a electrical wire connected to it via a plug which snapped. I tried to take a photo of it, but I couldn't take a clear picture of it.
If you click on the link, I think it is the bit on the left of the photo were the two hoses connect.
http://www.ricambio.co.uk/fiat-genuine-en/2815-carburettor-top-rubber-seal--fiat-126?sort=p.model&order=ASC&page=4
What is it?
Re: Not sure what this is.
« Reply #1 on: October 04, 2017, 09:47:42 PM »
That's the solenoid that operates the vacuum on the carb to increase the rev's when the electric fan kicks in
« Reply #2 on: October 04, 2017, 10:34:34 PM »
Many thanks Pete. I think because of the broken wiring, the solenoid isn't working. A piece of the metal terminal that protrudes from the solenoid is broken and is stuck in the plastic plug. Is the solenoid still available?
The idling very slightly decreases when the fan switches on (usually 5 second bursts). That is when I usually bring the choke up slightly to compensate.
« Reply #3 on: October 04, 2017, 10:36:19 PM »
Xylaquin
« Reply #4 on: October 05, 2017, 04:35:08 PM »
If you can wait a few days for delivery then get it for half the price at Regmot:
http://sklep.regmot.com.pl/elektrozawor-biegu-jalowego-fiat-126p-bis-oe-4406,3,14118,16013
« Reply #5 on: October 09, 2017, 09:10:36 PM »
I am interested. Will you be travelling to Poland?
Xylaquin
« Reply #6 on: October 09, 2017, 11:37:40 PM »
No, but they deliver to the UK  :D
Piotross
« Reply #7 on: October 10, 2017, 01:04:19 PM »
I got this part, factory new for BIS
« Reply #8 on: October 14, 2017, 08:31:54 AM »
Hi Piotross,
How much?
Piotross
« Reply #9 on: October 14, 2017, 03:18:49 PM »
Look at private messages
