Author Topic: Fiat 126p el 1994 column switch  (Read 2342 times)
William_Bouette
« on: September 24, 2017, 06:43:21 PM »
Hi all,
I'm having some trouble getting my headlamps to work on my 1994 fiat 126p el. When I bought it they were wired in using some extra switches but id like to get them working using the original column switches.
Should I be using the 2 or three position switch?
Also, if anyone has the correct wiring diagram for this model it would be much appreciated!
Many thanks,
Will
Re: Fiat 126p el 1994 column switch
« Reply #1 on: September 24, 2017, 10:37:12 PM »
 I should have some EL parts in the shed. I'll have a look tomorrow and let you know if I've got a switch..
 Nice to see someone else in the Tunbridge Wells area 8)
William_Bouette
« Reply #2 on: September 25, 2017, 09:01:36 AM »
Nice one, thanks!
Yeah good to know someone else in the area  :)
« Reply #3 on: September 25, 2017, 12:46:20 PM »
 You've got a PM.
« Reply #4 on: September 25, 2017, 11:44:56 PM »
When you replace the switch, they need to be just nipped up because if you over tighten them some of the switch position won't work ;)
