Author Topic: Tinware rattles.  (Read 2533 times)
Tinware rattles.
« on: July 07, 2017, 03:01:21 PM »
I took the air cowling off because there was a bit of a rattle. It turns out there were a number of bolts missing!
On top of that this bit had broken off!
Sent from my D5803 using Tapatalk
Re: Tinware rattles.
« Reply #1 on: July 07, 2017, 07:15:34 PM »
I had another set ready to go and a complete set of bolts.
The colour might not be to everyone's taste, but it does make it very easy to spot oil leaks!
« Reply #2 on: July 07, 2017, 07:21:02 PM »
I had a massive oil leak from the rocker cover gasket last weekend. I had replaced a worn leaking one with a new old stock one. I think it must have been a new very very old stock gasket! It lasted less the 3 miles before it split. Within a 15 minute drive I'd deposited about 2 litres of oil along some country lanes. I've now replaced it with a Cork one and 25 miles later no leaks.
Fingers crossed!
drcdb15
« Reply #3 on: July 08, 2017, 02:24:50 PM »
Good to see you in touch with your feminine side, Mike - we'll find you reading the instruction book next !! :P
« Reply #4 on: July 09, 2017, 06:14:51 PM »
Good to see you in touch with your feminine side, Mike - we'll find you reading the instruction book next !! [emoji14]
I take offence to that.
I don't use instructions!
