Author Topic: Which indicator/light switch do I need?  (Read 2642 times)
stephenc
« on: July 05, 2017, 02:30:40 PM »
I was fitting my new ignition switch today, then found that the indicator switch unit is broken inside so the bit with the switches isn't attached to the clamp bit anymore. :(
The switch has 3 connector blocks, all with 4 contacts- does this mean any 126 switch unit with the same number of contacts will fit (and work)?
Thanks for any advice you guys can give a newbie!
midvillesb
Re: Which indicator/light switch do I need?
« Reply #1 on: July 05, 2017, 06:32:52 PM »
Short answer is yes!
Presumably yours is an early car (round-ish instrument binnacle and single speed wipers) with connections as per the photo below?  If so, the Club may still have some brand new switches available and if not I still have a couple...
midvillesb
« Reply #2 on: July 05, 2017, 06:33:28 PM »
Oops, forgot the photo...
stephenc
« Reply #3 on: July 05, 2017, 09:19:58 PM »
Hi midvillesb
Yes, it is an early one- thread here- http://club126uk.co.uk/forum/index.php?topic=10879.0
Those are the same sort of connectors that mine has. Please let me know about the switches you have.  :)
midvillesb
« Reply #4 on: July 05, 2017, 10:47:34 PM »
Hi midvillesb
That's a great project you've got going on there!
Here's a link to my original post about the new column switches - http://club126uk.co.uk/forum/index.php?topic=7049.0
I must admit I'd forgotten that I still had a few left - I haven't sold one since 2013...
stephenc
« Reply #5 on: July 05, 2017, 11:59:24 PM »
Just read that thread- wow- that is dedication and commitment to the 126 cause indeed!
I am interested in one of your switches- I'll send you a PM!
