Fiat 126 Chat
126BIS Clutch Cable
Pages: [
Topic: 126BIS Clutch Cable (Read 2262 times)
andyzeetec
Subscribers
126 BIS
126BIS Clutch Cable
on:
May 18, 2017, 04:47:59 PM »
Does anyone know if Fiat 126/500 clutch cables are the same?
Ricambio are listing it as the same part, thought I would just check.
http://www.ricambio.co.uk/204-clutch-cable--fiat-500-r--126-all-models
Pedal is creaking a bit
so thinking its on the way out.
Found this..
• INNER CABLE LENGTH- 2060mm
• OUTTER CABLE LENGTH- 330mm
Subscriber VIP+
Re: 126BIS Clutch Cable
Reply #1 on:
May 18, 2017, 05:55:53 PM »
Sure it will be fine, the main difference is that the 500 cable had the mount bracket to the gearbox welded on to the outer cable and on the 126 the bracket is a separate item
andyzeetec
Subscribers
126 BIS
Reply #2 on:
May 24, 2017, 10:16:10 PM »
Thanks Rusty. Any idea where they tend to snap?
Pages: [
Fiat 126 Chat
126BIS Clutch Cable
