Author Topic: Broken (distributor?) wire  (Read 1756 times)
TheFiart
« on: December 08, 2016, 08:06:26 PM »
Hi all :)
I have a problem with my 1986 aircooled that currently won't start. The last time I worked on it a wire was worn down and the end connector had broken off.
I have stripped back the plastic and wrapped the wire around the thread and secured with the nut (picture 1) but I'm not sure which connector (out of the four on picture 2) it should be linked to.
Could someone shed some light? (see below images)
https://s17.postimg.org/o1abxa97z/photo_1.jpg
https://s16.postimg.org/mlvup69bp/photo_2.jpg
Thanks in advance!
Da Londo
    • Fiat 126 blog
Re: Broken (distributor?) wire
« Reply #1 on: December 09, 2016, 01:02:21 PM »
Looks alright.
TheFiart
« Reply #2 on: December 09, 2016, 02:14:17 PM »
I was a bit confused as there are two points with nothing connected!
