Author Topic: door card  (Read 2311 times)
crig
door card
« on: September 11, 2016, 01:00:25 PM »
Fiat 126 bis - Hi my nearside door card has come out at the bottom - how do I remove window handle /door handle - if I need to please ?
Re: door card
« Reply #1 on: September 11, 2016, 03:47:25 PM »
Two screws on each corner of the door pocket and the window winder has a kind of cir clip inside it between the handle and the round plastic boss. It's a bit fiddly it you need a thin screw driver to get between then and ping it out. After that it's just a case of carefully prising the door card off the clips.
crig
Re: door card
« Reply #2 on: September 11, 2016, 08:36:58 PM »
thanks Gadge what about door handle though ?
Xylaquin
Re: door card
« Reply #3 on: September 11, 2016, 09:25:52 PM »
If you hold the door handle surround by the top and bottom and start to twist it 90 degrees it should come out. The actual handle itself doesn't need to be removed.
crig
Re: door card
« Reply #4 on: September 14, 2016, 05:18:16 PM »
thanks again :)
