Author Topic: MCA Coupe  (Read 6398 times)
1300ot
MCA Coupe
« on: August 25, 2016, 07:15:12 PM »
Hello.
I've just purchased an MCA coupe that I will be restoring so I'll add a few photos as I progress. I could do with a little advice on the wheels/hubs if possible though.
It has the later 126 hubs and brakes fitted already, however I would like to fit some early wheels with the wider bolt pattern.  Is it possible to do the 'reverse' of the normal 500/126 hub conversion?
I'm guessing I'd need to replace the hubs/stub axle and complete brake drum units for the early ones?
Or more simply, could an adaptor be made up to fit?
Thanks in advance :)
Re: MCA Coupe
« Reply #1 on: August 25, 2016, 11:08:13 PM »
I believe you can buy adapter plates. I have seen them used on 500 disc brake conversions. I presume you can purchase the adapters.
https://www.fiat500ricambi.com/beheer/fotos2/RS1069_groot.jpg?v=1472162926
An alternative is to use rear drums if they fit your front
https://www.fiat500ricambi.com/beheer/fotos2/RS1017_groot.jpg?v=1472163253
« Last Edit: August 25, 2016, 11:17:17 PM by thepuddlejumper »
Re: MCA Coupe
« Reply #2 on: August 26, 2016, 11:22:27 AM »
I have got a spare pair of adapter plates if you are going down that route  :)
1300ot
Re: MCA Coupe
« Reply #3 on: August 27, 2016, 08:33:24 AM »
Thanks Ralph.  Rusty's Uncle - I have sent you a pm
amam
Re: MCA Coupe
« Reply #4 on: October 02, 2016, 07:49:53 PM »
good luck with it
looks like its been modified over the years, i believe it was built around a early 126 so would of had the older style of brakes since it had those nice wheels
« Last Edit: October 10, 2016, 02:05:59 PM by amam »
1300ot
Re: MCA Coupe
« Reply #5 on: November 13, 2016, 02:37:22 PM »
Thanks for the advice and help - in particular Rusty's Uncle - thanks for the bits!
I've attached some photos of a stripped down MCA.......
Will be going back together soon.
1300ot
Re: MCA Coupe
« Reply #6 on: February 05, 2017, 01:42:49 PM »
Chassis is back and powdercoated.
If ever anyone needs some classic car parts blasted/powdercoated I can highly recommend Maldon Shotblasting and Powdercoating in Essex.....
amam
Re: MCA Coupe
« Reply #7 on: February 05, 2017, 03:07:38 PM »
wow that looks amazing, is the body going to be the original turquoise colour?
1300ot
Re: MCA Coupe
« Reply #8 on: May 16, 2017, 04:03:51 PM »
Thanks very much to amam for supplying two badges! I have sent some good karma your way.  Yes, I've gone for turquoise.......
Re: MCA Coupe
« Reply #9 on: May 17, 2017, 01:56:26 PM »
 Wow great work there :thumbup It is starting to come together.
