Author Topic: Sheared wheel bolt - what is this called?  (Read 7841 times)
craigdiver
  • Fiat 126 ELX
« on: July 10, 2016, 09:55:11 AM »
Hi all,
My 126 came with 4 soft as s#!te locking wheel bolts (with no key). First one I tried (O/S REAR) to remove sheared. Had a go with an easy-out but drilled off-centre and also well and truly welded in with galling. Think will need a new hub (as per photo below). What is the part called I need to replace that takes the wheel bolts?
« Last Edit: July 10, 2016, 09:57:43 AM by craigdiver »
If it ain't broken, fix it anyway (just because).
Re: Sheared wheel bolt - what is this called?
« Reply #2 on: July 10, 2016, 10:17:23 AM »
 Do you need both the rear hubs, or just one?
 I can have a look in my shed to see what I`ve got.
craigdiver
  • Fiat 126 ELX
« Reply #3 on: July 10, 2016, 10:22:30 AM »
Think just the one as if another shears ill give it to a professional to remove the sheared part with heat etc.
If you have one please let me know how much you want for it and ill arrange the carriage.
Cheers 👍🏻
Craig
craigdiver
  • Fiat 126 ELX
« Reply #4 on: July 10, 2016, 10:25:34 AM »
Is it worth buying the Haynes Fiat 126 Haynes 1973-77 manual? How mechanically  similiar is my 1999 aircooled ELX to the original aircooled cars?
« Reply #5 on: July 10, 2016, 10:29:40 AM »
 No problem, I`ll have a look laters and let you know. I`ve got few rear suspension arms in the shed, so shouldn`t be a problem.
 It`s definitely worth buying a Haynes manual, or there should be one somewhere on the forum if you are a subscriber ;)
andyzeetec
  • 126 BIS
« Reply #6 on: July 10, 2016, 05:53:36 PM »
If you havent gone into the thread, it might be worth having a go at the remains of the bolt with a center punch and hammer tapping it round and out.
« Reply #7 on: July 10, 2016, 06:24:11 PM »
Perhaps (if the thread is not damaged), put the brake drum back on and then try drilling the broken stud out, start with a drill the same diameter as the brake drum hole just to find the centre, and then work up in drill sizes..
craigdiver
  • Fiat 126 ELX
« Reply #8 on: July 10, 2016, 06:31:36 PM »
Hi Andy, quite a bit of experience of stubborn fasteners and this one appears to be a pig, not helped by me drilling the hole off-centre for the easy out. Had a go with the punch but stud very soft and not going anywhere easily
craigdiver
  • Fiat 126 ELX
« Reply #9 on: July 10, 2016, 06:35:22 PM »
Chris, this is great advice that I wished I had had before I started! Think this one is beyond it though.
Cheers 👍🏻
craigdiver
  • Fiat 126 ELX
« Reply #10 on: July 10, 2016, 06:45:22 PM »
AND, I have a feeling when I try to remove the locking bolts from the other three wheels they will shear too 😳
Bambino126
« Reply #11 on: July 11, 2016, 02:26:52 PM »
Could it be Heli-coiled?
craigdiver
  • Fiat 126 ELX
« Reply #12 on: July 11, 2016, 04:06:13 PM »
Not keen on heli-coiling wheel bolts (or using helicoils in general!) as not a blind hole and difficult to see if it is seated correctly and not screwed through the hole.
Thanks for the input anyway 👍🏻😀
« Reply #13 on: July 11, 2016, 05:39:53 PM »
You could always fill the hole with weld and then re-thread. It may be worth checking if your aftermarket locking wheel studs are the correct thread pitch, I think Fiat used two different thread pitches on 126 wheel studs..?
« Reply #14 on: July 11, 2016, 05:49:59 PM »
Those locking wheel bolts really do work then  :o but I guess that it is the unlocking bit that is the problem.
You must have got enough purchase on the bolt to shear it. Have you tried the other bolts? I think that you are wasting your time with so called easy outs because of the forces involved.
