Author Topic: Replace side window glass - ELX  (Read 2288 times)
craigdiver
  • Fiat 126 ELX
« on: June 30, 2016, 05:38:06 PM »
Hi folks,
Can anyone give me some guidance on swapping the side window on my Fiat 126 ELX (the current glass has a score right down it where it has been rubbing on something)
I would guess at;
1) remove winder handle & door card
2) remove winder mechanism
??3) remove trim at base of window
4) rotate and remove glass up through bottom of window frame?
Photo of window;
If it ain't broken, fix it anyway (just because).
craigdiver
  • Fiat 126 ELX
Re: Replace side window glass - ELX
« Reply #1 on: July 06, 2016, 09:04:27 PM »
Managed to get the information from Lucas (LP garage);
This model its easy just remove door panel and undo all the 10mm spanner bolts, the glass will go easy.
Hope this helps someone else.
Ricksy1121
« Reply #2 on: August 25, 2019, 10:46:22 AM »
Anyone know if this glass can be used to replace the the other type with the main and 1/4 glass. Can it be retro fitted and what changes would be needed
