Author Topic: Bis carb part  (Read 2972 times)
Bis carb part
« on: June 26, 2016, 05:30:21 PM »
Does the Bis carb have a small Spring clip on the choke linkage? Same sort of thing as the ones on the air cooled throttle link but much smaller as it fits a 3mms rod. The Panda 30 Weber DGF has one so the Bis may have one as well and it would be even better if someone had some old carb bits as I need 2 for a Weber 30DIC  :)
dadandlad
Re: Bis carb part
« Reply #1 on: June 26, 2016, 07:00:45 PM »
Hi Rusty
Do you mean the E clip ?
If so I can provide you with a couple
Re: Bis carb part
« Reply #2 on: June 26, 2016, 08:26:08 PM »
I had to google e clip to see what they are, thanks for the offer but if they are like a circlip then it is not the part. I would post a picture but ever since this site got updated I can't work out how to do what was just a click of the button  :(
Re: Bis carb part
« Reply #3 on: June 26, 2016, 11:48:56 PM »
Should be a simple matter of just attaching an image. See pic
Re: Bis carb part
« Reply #4 on: June 30, 2016, 06:16:20 PM »
Hi Rusty
The latest news on this is that I rang Webcon , they e-mailed me an exploded diagram of a Weber 30DIC carb with part numbers for me to identify which parts I wanted which I did and they did not bother to get back to me. In the meantime , for a trial , I ordered a small selection of the E clips from ebay so I could see if they would do the job and what might be a suitable size. I managed to fit a 2.3mm clip onto the 3mm shaft and it works fine but so very hard to fit as it is like micro engineering. Two pinged off never to be seen again and I broke 1 when trying to fit them so if you do have a couple more clips that would be appreciated. So I am nearly there bringing another rare carb back to life  :)
dadandlad
Re: Bis carb part
« Reply #5 on: July 03, 2016, 07:52:08 PM »
Hi Rusty
No problem PM me your address and I will put a selection in the post for you
