Author Topic: Rear coil springs  (Read 2546 times)
cider
Rear coil springs
« on: June 09, 2016, 08:29:43 PM »
Hi Are the rear coil springs the same on both air cooled and the bis please
Da Londo
    • Fiat 126 blog
Re: Rear coil springs
« Reply #1 on: June 10, 2016, 01:00:39 PM »
I think they are the same yes, shock absorber is different.
cider
« Reply #2 on: June 10, 2016, 07:18:42 PM »
Thank you
« Reply #3 on: June 13, 2016, 06:41:52 AM »
No they are different  :( I made that mistake. The aircooled one is at least one coil taller so when I fitted it the back end stuck right up in the air. I ended up cutting a coil out so it was the same height. That said it wasn't such a big deal doing it because I'm tuning harder shocks which made up for the softer spring
« Reply #4 on: June 13, 2016, 12:34:01 PM »
Hi, does that mean you can use the springs form a Bis to lower an air cooled?
« Reply #5 on: June 13, 2016, 05:30:35 PM »
I'm not sure :( I think the reason for the difference is because maybe the aircooled was heavier? In theory the suspension geometry is the same so adding BIS springs shouldn't make it lower but maybe it'll make it firmer
Bambino126
« Reply #6 on: June 17, 2016, 11:33:46 AM »
I fitted this spring from Axel Gerstl to my Bis.
http://webshop.fiat500126.com/katalog/artikelinfo/1450/coil-spring-rear
The arse of the car sat right up in the air! Had to cut coils off to get it down.
So no, Aircooled and Bis springs are different.
I realised that if something says "Fits Fiat 126" then that implies Aircooled.
If its for your Bis then it needs to specifically say "suitable for Bis"
Joe Webb
« Reply #7 on: June 28, 2016, 10:12:17 PM »
If BIS is lighter, wouldn't adding BIS springs to an aircooled make it less firm?
would be good if you could use them to lower the aircooled though
