Answer yes they leak, Answer the think ones, ditch the others.
Hi, not been around for a while myself so hello to all those who remember me and hi to those who don,t.
Now your going to ask next by how much oil leaks and can there be a cure, what I've done over the years is put a very small under cut with a large drill into the cylinder head then on assembly fitted O rings under the washers you mentioned.
Good luck hope that helps. Smallcox
