Fiat 126 Chat
gear change linkage
Pages: [
Topic: gear change linkage (Read 1897 times)
amam
gear change linkage
on:
May 22, 2016, 04:28:27 PM »
well on another thread i said on my MCA kit car (based on a 79 aircooled fiat 126) is pretty difficult to engage reverse gear, trying to do it even when pressing the gear stick down it 99% of the time engages 4th instead of reverse
the whole gear change doesnt seem very positive
i tried to adjust the linkage as it says in the haynes manual but hasn't made much difference
took a closer look and you can even see some of the broken bush under the gear stick
im guessing this is the kit i need? and also is there anything else i need to improve it
http://www.superflex.co.uk/proddetail.php?prod=SF115-2899K
Last Edit: May 22, 2016, 06:57:30 PM by amam
bbrynek
Newbie
Re: gear change linkage
Reply #1 on:
May 23, 2016, 10:37:40 AM »
Hello
from your own experience suggests seen on these items
The problem can be worn with a gearbox rod coupling (loose)
or gear selector, to exchange
gear stick rather will be at the end of the suspect
Pages: [
Fiat 126 Chat
gear change linkage
