Author Topic: low hanging door/out of line  (Read 2528 times)
DannyPancho
« on: May 11, 2016, 05:43:57 PM »
hi guys, ive got a small problem with my drivers side door hanging too low and as a result, the door wont shut properly and is starting to scrape the paint off the sill...
anyone know any way of fixing this? ive been fiddling with it and have made the gap slightly smaller but its still ridiculously out of line...
any and all help would be great!
cheers
Dan
Fiat 126 DeVille
Re: low hanging door/out of line
« Reply #1 on: May 11, 2016, 06:48:26 PM »
assuming the door pillar is sound, I'd get 2 hands underneath the end and try lifting the door up ;)
DannyPancho
« Reply #2 on: May 11, 2016, 09:42:16 PM »
Ive hada look and the door is solid in its place (wiggle the door and the car moves) and the pillar appears to be sound! Believe it may be the hinges...  ???
Cheers!!
Fiat 126 DeVille
DeVilleChris
    • Club 126 UK
« Reply #3 on: May 11, 2016, 10:14:21 PM »
Car door has always been like that, you can close it but it takes a bit of force... its because of the door hinges, I think it got a knock on the drive when we had it.
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
DannyPancho
« Reply #4 on: May 11, 2016, 10:22:12 PM »
Aah okay that sounds fair enough, you reckon there may be some damage? Or just some new hinges might do?  :)
Fiat 126 DeVille
dadandlad
« Reply #5 on: May 13, 2016, 11:19:25 PM »
As Pete said try lifting the door with two hands
I had to adjust mine this way,  open the door six inch or so and lift at the back end
You dont want to do it with it fully open though
DannyPancho
« Reply #6 on: May 16, 2016, 08:11:02 PM »
went back and tried what you guys suggested, opened the door about 6 or so  inches, loosened the bolts, lifted up the door from the end and placed a bucket underneath to keep it there while i tightened the bolts again - i moved the bucket and the door just dropped again - definitely believe its the hinges as this is where the wobbling is coming from
thanks for the help though guys  :)
Fiat 126 DeVille
« Reply #7 on: May 16, 2016, 09:13:01 PM »
If the pins in the hinges are worn you will have to repair
