Author Topic: Wheel trims  (Read 2654 times)
Iansmi1972
Wheel trims
« on: April 10, 2016, 01:08:38 PM »
Does anyone happen to know where I can buy a new set of wheel trims for a 126?. I have spent ages on the web and can't find any original parts
Thanks again
dadandlad
Iansmi1972
Re: Wheel trims
« Reply #2 on: April 10, 2016, 07:53:58 PM »
Saw these but they look badly scratched was hoping to find a supplier that my have some :(
dombooth
Re: Wheel trims
« Reply #3 on: April 10, 2016, 11:20:05 PM »
Very unlikely to find any new.
Piotross would be the best chance at finding some
Bambino126
Re: Wheel trims
« Reply #4 on: April 11, 2016, 02:10:51 AM »
You could re-spray them with a can I'm sure they'd look as good as new
drcdb15
Re: Wheel trims
« Reply #5 on: April 11, 2016, 11:46:00 PM »
Refurbishing the used trims from eBay is probably your best bet. There's nothing magical about wheel trims, they are simply painted plastic mouldings (used to work with OEM moulders and paint finishers). So they can be sprayed pretty much like any steel bodywork.
Remember that the base material is softer than steel, and much more flexible, so don't go too heavy handed. I'd suggest careful masking of the central "FIAT" logo, then gently rub down the rest of the trim to give a key for the paint. Then spray as usual - lots of thin coats rather than one heavy one. Probably a good idea to do a final coat or two of clear gloss to make them nice and shiny. Use something like this:
http://www.ebay.co.uk/itm/Simoniz-5-Wheel-Silver-500ml-Paint-For-Alloy-Rims-Re-Spray-Aerosol-Spray-Can-/301870942915?hash=item4648e90ac3:g:OzYAAOSwFNZWvaWw
Although in searching I see that many solid colours are also available if you fancy a change away from the usual silver.
Before painting, repair any deep gouges by trimming away (use Stanley knife with brand new blade) material standing proud at the edges of the gouge, then fill  the gouge itself with paint. Spray the paint in a short burst into a small container to get a puddle of liquid, then dip a cotton bud into this and use like a small paint brush to dab drops into the gouge. Let it dry thoroughly and build up in small doses. This may take several days depending on how deep the gouge is, but like any paintwork, the longer you take on the preparation the better the final result.
I'd advise against trying to rub down the surface to 'polish out' any deep gouges, as you're likely to break through the paint layers into the plastic below. Getting paint to adhere to plastic is no easy task, far easier to get your paint to adhere to the lower layers of paint the manufacturers put down. So just very gentle abrading of the surface, just enough to key the surface to give your spray something to grip onto.
drcdb15
Re: Wheel trims
« Reply #6 on: April 11, 2016, 11:54:40 PM »
Sorry, meant to say, when I talk about 'rubbing down', I mean using a cutting compound like T-Cut, rather than seriously abrasive media such as wet & dry paper etc. Looking at the eBay picture, these trims look to me to be in pretty fair nick, and most of the marks are surface scrubbing rather than deep cuts. So I think Bambino is right, they'll likely come up pretty good.
