Author Topic: New ceiling: did anyone else did it this way?  (Read 3398 times)
Frigorius
« on: March 17, 2016, 12:19:10 PM »
Few years ago, the ceiling of my Fiat 126 Bis started to come down. Certain moment, while explaining this to someone, I tore a little crack in it. Whilst this was exactly hanging in my face and giving a lot of dust, I decided to put a new ceiling in it.
When I started cutting, I discovered there was a wooden plate underneath it, and what appeared to be the rest of some isolating fiber. Which gave a lot more dust
This is where the drivers seat was normally located. A looooooot of dust  :)
At first, I was doing this very secure, slowly and making sure I did not break anything.
But that didn't take long, as I started pulling "a little heavier" towards the end
Which you can't actually see on this picture, but you can believe me when I say the ceiling did not had any plans in the direction of leaving the car, before I started pulling. Quite robust, I'd say.
But I won:
Now I could start the manufacturing of a new ceiling.
I added the tape, to make sure there was no trembling going on up there
While I'm not such a good craftsmen, I had to screw - unscrew most of these planks numerous times.
And then again.
For example: did you know you can never fit in that fifth one, if you don't unscrew the fourth and the middle one?
Try to put the screw in a nice straight line. By measuring and drawing a line, as some one said to me later, in stead of trying to do that with eye sight.
In a later stadium, I have changed the sun flaps (? ). In the future, I will add speakers to the ceiling too. And maybe some lights.
Hope you liked the story.
Bambino126
Re: New ceiling: did anyone else did it this way?
« Reply #1 on: March 24, 2016, 06:05:01 PM »
Wow  :o never seen a 126 with a solid thick wooden roof lining before. Looks good and good luck to you.
Doesn't your head bump on it?
« Reply #2 on: March 24, 2016, 08:09:36 PM »
Different :o  ;D
126blackbird
« Reply #3 on: March 24, 2016, 09:03:44 PM »
Very handy if you roll it on its roof....................... LOL
Da Londo
    • Fiat 126 blog
« Reply #4 on: March 25, 2016, 08:38:09 AM »
Adds a lot of weight this.
Frigorius
« Reply #5 on: March 25, 2016, 11:17:16 AM »
@Bambino 126: I have order new seat springs, so mayby my head will bounce again it then. But for the moment I still have 18 cm free space :-). I'm not so big myself :-)
@Da Londo: This I very thin wood, I guess it adds ten kg at most.
@126 Blackbird: let's not try that :-)
