Author Topic: Not a good day to many flashing lights  (Read 2588 times)
cider
« on: February 13, 2016, 09:54:59 PM »
Well It was all going to plan "radiator cowling repaired and refitted, new bearings in the alternator refilled gearbox
and new plugs and leads" so its time to bleed the cooling system,miss fire now sorted :)  cooling system now sorted.
Things are on the up,Until The fan is switched on :cry:most of the instrument warning lights are now on with both fuel and temp gauges are off the scale :(. When you switch the fan off all lights and gauges return to normal
Heres whats been done
fan switch swopped over as to the fan unit ,different instrument panel and cleaned main battery earth
And stll it lit up like a christmas tree >:(
Are there any more earth points on the bis in the front
Now time for a jar of cider and maybe them pixies will sort it ::)
Pete
dadandlad
Re: Not a good day to many flashing lights
« Reply #1 on: February 13, 2016, 10:15:56 PM »
Hi Pete
There is certainly a earth point on the OSF inner wing and from memory I can't remember if there is one on the NS
Also might be worth checking main engine earth
Bad earths can cause some really strange faults but usually easily fixed
cider
« Reply #2 on: February 13, 2016, 10:45:13 PM »
Yep The main earth been done cleaned with a new bolt and washers fitted :),seem the wiring diagram on the bis cd  must be for an early model bis and not the 1991 version >:( On my fan switch theres two black wires "Earths I believe" one goes to the instrument panel connector B "red" pin 5 and the other I`m not sure at the moment.What I might do is to snip that one  The unknown and run a new earth, but then it might be earth for something else further down the line ::)
More Cider needed :P
Pete
dadandlad
« Reply #3 on: February 14, 2016, 09:35:07 AM »
Just looked at wiring diagram and the fan shares its earth with the OSF indicator and the earth point is as I said on the inner wing
Hope this helps
cider
« Reply #4 on: February 16, 2016, 05:06:47 PM »
Thank you for your help :D
Just found the earths and they`re behind the washer bags,both look excellent so must be a wire related issue
New wire made and ready to fit :)
Pete
« Reply #5 on: February 16, 2016, 05:43:47 PM »
I always rub all the bits on the earth with a bit of coper grease. Helps keep the rust away...at least, that's the theory.
cider
« Reply #6 on: February 17, 2016, 10:09:13 PM »
I`ve fitted a new earth  and all warning lights and gauges are back to normal ;D.Buuuuuuuuuuuuuuuuuuut
Now The directional indicators are playing up >:(  :(
cider
« Reply #7 on: February 20, 2016, 03:46:58 AM »
All sorted found and replaced the offending wire
So we have indicators
Just waiting for the next issue  to pop along
« Reply #8 on: February 20, 2016, 09:18:48 AM »
That's the Spirit :D Look forward to the next faults :P
