Author Topic: interior panels and engine fired!  (Read 213027 times)
Re: Stuey's 126 underbonnet and interior painting commences
« Reply #420 on: June 04, 2015, 09:37:13 PM »
Finally got the interior Painted!
dadandlad
Re: Stuey's 126 underbonnet and interior painting finished!
« Reply #421 on: June 04, 2015, 10:03:13 PM »
Looking really good, nice job on the interior paint
« Reply #422 on: June 05, 2015, 09:28:12 PM »
thanks, Its one more thing off the list, Today I cabled up the clutch, re welded the accelerator pedal as it had snapped, put in the steering shaft and connected the wheel to the rack, just the wiring for the switches on the centre to do and connecting it all to the existing loom then I'm ready for exterior paint. I'm really pleased! (need to sort that steering wheel as well)
Re: Stuey's 126 interior wiring
« Reply #423 on: June 05, 2015, 11:23:47 PM »
The wiring to the centre console is the last thing that needs to run through the car and since i had a little down time at work and a steady supply of electrical cable I thought I'd finish it up!
« Reply #424 on: June 06, 2015, 09:01:56 AM »
Looking great :thumbup: also good job on the paintwork, I wish I could do as good a job as that at home :)
« Reply #425 on: June 09, 2015, 10:01:47 PM »
Finally got all of the interior stuff finished, no thing to remove or redo, so I now need to sort out the loom refit the engine and then it's paint time!
« Reply #426 on: June 09, 2015, 10:16:30 PM »
Success is moments away my friend  ;D I hope your fitting seat cushions in those seat frames or your gonna get sores  :D
« Reply #427 on: June 10, 2015, 07:31:48 AM »
they do have a set of covers but the look way cooler without them.. ;D
sunriser81
« Reply #428 on: June 11, 2015, 07:45:46 PM »
Hi Stuey.
I need that fuel tank could you please help me?
Will it take Punto fuel pump?
Thanks Lucas
« Reply #429 on: June 11, 2015, 10:06:13 PM »
Hi Lucas I've had it for years and I don't even think the company that make it exists any more but it's just a alloy fuel cell so I'm sure you could get one that's very similar, you'd need to run an external fuel pump- I have a facet one I'm going to be using.
« Reply #430 on: June 12, 2015, 08:51:31 PM »
small update my gear knob is done- a recycled pump screw I borrowed from work-
this week I will be rebuilding the wiring loom, cleaning and refitting the engine (and building some sexy bbs for my z4 and another set to sell to partially finance the 126 repaint!
sunriser81
« Reply #431 on: June 14, 2015, 04:10:05 PM »
Hi Sorry I thought that fuel tank is made to take fuel pump fitted on top, but this is place for fuel filler (fuel cap on top) ?
In this case I have to convert standart 126 fuel tank to take pump in...
thanks
« Reply #432 on: June 17, 2015, 03:36:42 PM »
No problem Lucas- yes it is the fuel filler.
Today's work is wiring and wrapping the loom ready for the engine so I started buy re wrapping the rear loom-
From which I removed some stuff I won't need -
Which I've fitted In the car.
The. I've made a good start or the front loom-
[/URL
Which meant my pile of wire I won't use rose to this-
[URL=http://s7.photobucket.com/user/cheekos10/media/fiat%20126/3E8A85FA-3473-4FCE-99FB-FF0D7B32E9FB.jpg.html]
I now need to order a few dash tell lights and some switches to replace the dash pod ones then I can get the engine in and get it started ( first time in a while)
Re: Stuey's 126 wires and wires and wires
« Reply #433 on: July 08, 2015, 09:15:32 PM »
Tons more wiring to arse around with but I've managed to do a few bits-
Fitted a battery connection and starter cable-
A mounting for my dash tell lights which needs some finessing but goes in well-you can also see my abortive attempt to mount the lights in the dash which lead me to have to refill the dash and will have to paint it  >:(
Lastly I've put the tailgate latch pins in as I'm doing away with the solenoid mech as it was forever burning out-
« Reply #434 on: October 15, 2015, 06:49:36 PM »
Done a little this week- engine backin
And got the back panel stripped and punched the cheese holes-
