Author Topic: interior panels and engine fired!  (Read 213262 times)
Re: Stuey's 126-Bring on the stripper!
« Reply #330 on: July 08, 2012, 10:11:26 PM »
Last of the outside of the shell panels done-
Rear light panels-
Other wing and cill done
Next there is some minor welding to tidy up, knot brush all of the door and window apertures then a DA all over then it's time for filler!
« Reply #331 on: August 12, 2012, 10:36:55 PM »
Had a slow time at work today so I decided to do some fabrication...needs bending into shape and cosmetically finishing but im please and free is better than paying £40!
« Last Edit: August 13, 2012, 09:35:28 AM by stuey »
Re: Stuey's 126-FAB-rication!
« Reply #332 on: August 13, 2012, 10:07:19 AM »
Cool sandwich holder, but won't the mayonnaise pour out of the holes?
« Reply #333 on: August 13, 2012, 11:01:23 AM »
more of a pickle man my self - its a battery box (or will be once folded up)
« Reply #334 on: August 22, 2012, 03:59:53 PM »
A little progress today-
And with a battery in it-
And made the front mounts for the petrol tank-
Hopefully by the end of next week I'll have all the internal mountings done and can start the filler work :(
« Reply #335 on: August 22, 2012, 11:17:24 PM »
Panic over Stuey you got till the 18th August 2013 Retro Rides to sort it out, Like the work
Sent from Blackberry Torch  using Tapatalk
« Reply #336 on: December 12, 2012, 09:47:11 PM »
More done over the last few days- faricated seat mounts and got them in the car with the seats- both sides are done ( only one in there pics) I've mounted the side seat belts on the mounts so I can undo 4 bolts and remove the seats and belts together
Re: Stuey's 126-load the filler cannon!
« Reply #337 on: January 29, 2013, 11:34:08 PM »
Right i have finally welded and cut holes in everything i ever wanted so I'm moving onto filling up said battle scars- starting with the front boot -
i have removed the fuse box and front brake reservoir, they will be relocated into the area behind the dash  and hidden by a hinged panel (seen here as a basic cardboard template) the spare wheel and air horns will still live under the bonnet and I'm considering putting the battery back in its original location as I'm a little nervous about having a battery and a fuel tank located behind the drivers seat, I'm starting to feel its asking for trouble- any hoo I've started to fill it and smacked a little primer to protect the metal whilst i crack on with the interior filling... more soon-
(what looks like seagull poop in the middle is some white primer showing through where i ran out and had to use black.... )
« Reply #338 on: June 08, 2013, 03:55:28 PM »
Been fabricating some mounts for the brake resivour and the fuse box and got them mounted today next will be the air horns and compressor-
« Reply #339 on: June 08, 2013, 05:50:02 PM »
And air horns and compressor in with the newly relocated to the front battery ( had to make a new battery tray as I chopped ou the old one.. ::)
markymarc
« Reply #340 on: October 06, 2013, 11:04:14 AM »
I think we need an update?
Marc
« Reply #341 on: October 06, 2013, 06:55:39 PM »
Marc
its just lots of filler work at the mo... but I'll try to get something in soon I have my bodywork guy coming up to do the finishing of the prep ready for paint- and that will be great...
« Reply #342 on: December 01, 2013, 01:24:07 PM »
Filler work and other things continue but these arrived yesterday - my replacement air intakes and scoops which will be mounted in my Perspex windows. And yes they look a bit like she-pees!
markymarc
« Reply #343 on: December 10, 2013, 08:53:09 PM »
I'm as excited to see your motor as I was mine! I think it'll be right up my street? Do you have a colour in mind yet? Or same as before?
Marc
« Reply #344 on: December 11, 2013, 09:44:30 AM »
Going with the original colour- trying to pull off a retro racer type look (irony of that statement with a 704cc engine is not lost on me!)
