Author Topic: interior panels and engine fired!  (Read 213258 times)
Re: Stuey's 126-choppy choppy chop chop!
« Reply #165 on: March 14, 2009, 08:45:10 AM »
I recon it should look good, it will smooth out the body where the lights are at the moment.
« Reply #166 on: March 14, 2009, 11:56:41 AM »
O, Cool, 2 things just popped to mind, 1. Shouldnt you have done that before you painted the car  :P and 2, DAMN, those wheels sure stand out dont they  :D
« Reply #167 on: March 14, 2009, 12:15:40 PM »
1- Didnt really think about it until after I built the car but I have spare paint and access to a body shop so its no ish.
2- theyve been camber adjusted since its an old pic... ;D
« Reply #168 on: March 14, 2009, 12:50:07 PM »
 [-/ [-/ all is well then...  [-/ [-/
« Reply #169 on: March 14, 2009, 03:20:03 PM »
stu very vw golfish lol will look good no matter what people think thats what makes a good show car it rocks the boat .
Tomasz
« Reply #170 on: March 18, 2009, 11:45:10 PM »
should look goodi think, very slick.
« Reply #171 on: March 21, 2009, 05:32:21 PM »
A little more fettling today managed to get the hole more flush to the indicator and loose the bumper bolts so then just the other indicator hole then lots of sanding filing etc and I think its gonna work.... </ (oh and loose the old indicators....looks a little silly with both...
« Reply #172 on: March 23, 2009, 09:31:10 AM »
just a little question and i dont suppose any mot tester would ever spot it but is there a minimum height that an indicator must be for legal reasons?
« Reply #173 on: March 23, 2009, 05:41:06 PM »
checked here and doesnt seem so ( i hope- :D)
http://www.ukmot.com/1-5.asp#Text_top
« Reply #174 on: March 23, 2009, 06:37:54 PM »
thats good i said it because i know they have laws about headlight heights you see and didnt want to see you get a knock back on test day because of that.
« Reply #175 on: April 02, 2009, 08:07:36 PM »
started my strip down today in preparation for a new gearbox, disc brakes, the finish of the bumper mods and a freshen up on the engine to get rid of thems nasty leaks never had the engine out before its nice to know you can easily remove it by yourself without an engine crane-
Re: Stuey's 126-pulling it to bits!
« Reply #176 on: April 04, 2009, 06:35:18 PM »
Ahhhhhhh........ that brings back memories [-/. athough i'm suprised you did'nt pull the gearbox out with the engine?
« Last Edit: April 04, 2009, 06:36:53 PM by Gadge »
« Reply #177 on: April 04, 2009, 07:02:08 PM »
theyve got to be split anyway as I'm replacing the gear box and Ive never done it before so wasnt really sure how to disconnect the drive shafts... in hindsight it might have been easier... I managed got my first disc brake on today!!!
« Reply #178 on: April 04, 2009, 07:26:26 PM »
What exactly does one need to make/do to fit the discs?
And i always take the engine off first, then the box, its just lighter, and me and my bro can take it off without any problems...
What exactly do you intend to do with the engine?
Keep it up fella  [-/
« Reply #179 on: April 04, 2009, 08:54:02 PM »
the brake mechanism's are all cinquecento (disc pads calipers) the only special bits are the plates that bolt the caliper carriers to the car a set of spacers that got between the caliper carriers and the plates.
Im also using a set of cinq flexis connected to some longer relocated brake pipes and Im going to fit a bis valve to the rear brakes to ensure they dont pull up before the discs do...
Thes engine is just coming out for a freshen up clean and replacement of the gearbox which is knackered...
