Author Topic: Front wheel Bearing Torque setting  (Read 1894 times)
cider
« on: January 27, 2016, 09:42:21 PM »
What should the front wheel bearings be torqued too Please
Pete
dadandlad
Re: Front wheel Bearing Torque setting
« Reply #1 on: January 27, 2016, 10:06:23 PM »
According to the Haynes manual
Screw on a new nut and tighten to a torque of 5lb ft 7nm
Where a torque wrench is not available tighten the nut as hard as you can gripping it with the hands only.
Now unscrew the nut through 30 degrees which will give the correct endfloat of the drum/hub of between 0.001" and 0.004"    0.025mm and 0.100mm
« Reply #2 on: January 27, 2016, 10:16:29 PM »
Yes that's about right, it doesn't need to be that tight. Once staked it won't move  :D
cider
« Reply #3 on: January 27, 2016, 11:17:54 PM »
Thank you   :D :D
