Author Topic: Quick question  (Read 2172 times)
Bambino126
Quick question
« on: December 18, 2015, 03:11:45 PM »
On the BIS engine, is the distributor supposed to have some kind of seal or gasket fitted between it and the timing cover, to stop oil escaping?  :$
My engine is almost back together now, but when I disassembled it there was nothing present there.
mintex
Re: Quick question
« Reply #1 on: December 18, 2015, 05:09:56 PM »
Mine has an O ring just under the lip bud
Dave
Bambino126
Re: Quick question
« Reply #2 on: December 19, 2015, 02:33:10 PM »
Thanks.
Thats what I need to get.
Bambino126
Re: Quick question
« Reply #3 on: December 24, 2015, 02:40:10 AM »
Are the Zelmot and the Magnetti Marelli distributors completely interchangable on the BIS?
To me the MM dizzys seem to be a better design and are cheaper to buy.
Re: Quick question
« Reply #4 on: December 24, 2015, 05:03:27 AM »
Yes they are. I'm running a MM dizzy on mine as I went through 2 zelmot ones due to poor build quality on the base plates. The MM versions are a lot better and their points adjustment is a lot easier too as you adjust them via a hole in the side that accesses an Allen bolt that opens and closes the points - so much easier!  ;) the only snag is that the points are an all in one item like a kind of cassette that just drops in so they can be expensive - between £10 and even £21  :o
Bambino126
Re: Quick question
« Reply #5 on: December 24, 2015, 12:33:19 PM »
Thanks - I'm gonna take the plunge  :D
