Author Topic: Modifications of head  (Read 1891 times)
Piotross
« on: October 30, 2015, 02:08:41 PM »
I am offering modifications of head Fiat's 126 and 500 to get a lot more power of engine
Complete porting
Insert new guides
Insert new bigger valve seats
Insert new bigger valves  (other shape of valve, other angels of valve face- 30, 45 degrees
grinding of head of any height
Prices are dependent on the degree of modification
Rifart
Re: Modifications of head
« Reply #1 on: October 31, 2015, 08:41:20 AM »
Piotrek,
Do you have Hp rating for the modification packages ?
Suppose that if you modify only head, how many additional hp will come out ?
Do you also offer re-profiled camshafts, pistons etc.. ?
Piotross
« Reply #2 on: October 31, 2015, 10:54:19 AM »
Hp rating depends mostly from the head and camshaft.
Using these heads we can make 35-45 HP choosing appropriate camshaft (lighter flywheel, modified carb, air inlet)
To get adequate power, the engine should be in good condition
If somebody want to get more than 45 HP must a modify a lot of engine parts
Yep, I am making modifications of pistons :)
« Last Edit: October 31, 2015, 11:02:34 AM by Piotross »
