I'm in the process of building a custom wiring loom for my 500 and have a question. I assume that the 500 is the same as an early 126 with a lights on switch on the dash and then a three position arm on the steering column. My question is this: which order are the lights? side top of the arm, main middle, dipped bottom or is the order different?.
Nigel
