Author Topic: rocker cover removal - double check  (Read 1432 times)
FluxCo
  • 89 BIS
« on: December 07, 2010, 07:29:21 PM »
hello again
just want to double check with someone in the known:
1 - when taking off the rocker cover, the exhaust doesnt need to come off
2 - i dont need to drain the engine to take off the rocker cover
Re: rocker cover removal - double check
« Reply #1 on: December 07, 2010, 08:28:11 PM »
Yes you don't have to drain any of the fluids, and you don't have to remove the exhaust,
I usually put a thin bead of silicone sealer on the gasket then fit it to the clean rocker cover, leave it 10mins and then a thin bead on the other side, this helps stop the gasket from moving when its tightened up, Don't over tighten the cover or the rockers may touch the inside of the cover [-/
FluxCo
  • 89 BIS
« Reply #2 on: December 07, 2010, 09:07:12 PM »
coolio
thanks for the advice and the response
i ve been to halfords every day so far this week
looks like i will be going again tomorrow to get some silicon sealant (i knew i'd forgot something today)
FluxCo
  • 89 BIS
« Reply #3 on: December 08, 2010, 04:56:45 PM »
bit of an update
i had to undo the exhaust (from the manifold) to get clearance to take off the rocker cover
unfortunately, the wrong rocker cover gasket was sent out to me
fingers cross, i will get the correct part tomorrow and finish off the job
and i thought it wouldnt take more than an hour
doh!
