Author Topic: KINGPINS!  (Read 2732 times)
KINGPINS!
« on: August 18, 2010, 02:16:47 PM »
After replacing the brakes and re torquing the hub nuts it seems I have a lot of play in my near side kingpin I can actually see it moving about 2 - 3 mm,  I have pumped in loads of grease but it only comes out the top and not the bottom.  Do these need replacing and if so are these good value as they are reconditioned units....
http://cgi.ebay.co.uk/Reconditioned-Stub-Axles-Pair-Fiat-126-all-models-/290274578771?pt=UK_CarsParts_Vehicles_CarParts_SM
« Last Edit: August 18, 2010, 02:39:39 PM by ciaoflyer »
Re: KINGPINS!
« Reply #1 on: August 18, 2010, 07:16:37 PM »
You want to get the refurb set with two grease nipples to ensure the top and bottom get grease.
Allan
Re: KINGPINS!
« Reply #2 on: August 18, 2010, 10:53:29 PM »
Would like to know if 95 pounds is a good price for these? It looks like it includes top bushes too.
Re: KINGPINS!
« Reply #3 on: August 19, 2010, 01:29:05 PM »
Bought them and waiting for them to arrive!  These are a straight swop, take old ones off put new on grease and bobs your uncle.  Ricambio have told me that they have been reconditioned with brass bushes and not the plastic ones.
Let you know what they are like when I get!
Re: KINGPINS!
« Reply #4 on: August 25, 2010, 08:19:44 PM »
OK stripped one side!  Break nipple seized so going to fit new break pipes, I can't believe how cheap they are!  Anyhow here are some pics of the parts before being hammerited....
Also fitting new flexi hoses!
Re: KINGPINS!
« Reply #5 on: August 25, 2010, 11:33:02 PM »
Try some braided hoses if you can, the difference is amazing I thought [-/
Re: KINGPINS!
« Reply #6 on: September 19, 2010, 08:40:09 PM »
OK all replaced will post a pic soon, however the haynes manual for an aircooled says that the top nut on the stub axle is 44ftlbs and the bottom which connects to the spring 29ftlbs, is this the same for the Bis?
Also it says tighten them after the wheels are back on the ground to avoid distorting flexible bushes, but I have found that this is near impossible can it be done without the wheel on is it really a problem?
Ta
Re: KINGPINS!
« Reply #7 on: September 19, 2010, 09:35:43 PM »
I was able to tighten the top arm nuts (if that's the one your asking about) by turning the wheels one way then in another direction. The BIS has 13 inch wheels standard so i think  maybe that's why there's less room there.
You can try and tighten them without the wheel on by lifting one side of the suspension up with a jack (at the leaf spring eye), which will be near enough as if the weight was on it.
Re: KINGPINS!
« Reply #8 on: September 20, 2010, 09:10:05 AM »
tightened without weight of car and now on the full weight will this of broke them?
ta
Re: KINGPINS!
« Reply #9 on: September 20, 2010, 10:16:19 PM »
I found there was enough room to tighten the nuts for the stub axle and leaf spring eye bush with the car on the ground. Just had to steer the wheel out so that the wrench would go onto the nut and have a spanner or wrench on the bolt head in case it would turn at the same time, though after a few turns of the nut the bolt didn't budge...
Re: KINGPINS!
« Reply #10 on: September 21, 2010, 06:59:53 AM »
Thanks for your help GT, I ended up taking the wheels off putting the car on stands.  I marked the stub axel with a pencil and then jacked it up until it reached the mark as if it were on the ground then I tightened it!
Re: KINGPINS!
« Reply #11 on: September 26, 2010, 03:47:06 PM »
Here's the progress, all nearly finished now....
Re: KINGPINS!
« Reply #12 on: September 26, 2010, 07:46:10 PM »
You shouldn't see rust now for a long time  [-/
