Can anyone here help, i am putting a late 126 engine in my fiat 500, which has the old pull type starter, the new 126 engine has the solonoid starter. The question is how do i wire it , it has 3 connection at the back one spins the starter which is a bolt on connection, a small spade type conector which engages the solonoid, then i have one bolt connection left what is it is it for an earth strap??.
Anyway how does it wire up, i was thinking that i need to run a cable to a push button starter from the batt+ then out of the pushbutton to the bolt connector that turns the starter, then also connect the solonoid to this too so that they both fire at the same time???
