Driving at high speed the car will die then come back, but drive at 40ish all OK. Therefore I assumed a fuel supply problem, had something similar on my 500 that turned out to be the pump drive pin from the camshaft was worn. All seemed to check out OK then noticed a lot of air bubles coming from the petrol tank to the pump, thought it might be rust damage to the outlet pipe from the tank. Cut an inspection hole in the seat area to view the sender/fuel supply unit and sure enough the outlet pipe is corroded but no signs of damp, the tank is 3/4 full. Is this a common problem any ideas of what is wrong do I need a new sender/fuel supply unit and if so where can I buy one.
