Author Topic: The old Bis headgasket problem!  (Read 2736 times)
« on: March 14, 2007, 07:20:48 PM »
Is the only reason for a Bis to blow it's head beacause of it getting too hot or are there other reasons?  What I'm asking is that if I keep it cool will in never blow it's gasket?
« Reply #1 on: March 14, 2007, 08:54:35 PM »
the stud pattern is non to clever either.......if the guy in the factory didnt care,or the last clot who did the head gasket didnt,(the correct thick washers,and clean threads are crucial to spread the load )it will go again,but cool is good,and re torqued head bolts are added insurance(loosen half turn when cold,then re torque).
also,ive noticed thet studs can be badly corroded in engines with the wrong coolent,this must cause them to stretch/relax and let the head loose???................................. :?:
jpimpao
« Reply #2 on: March 15, 2007, 12:40:12 AM »
Is there any special tool to re torque the head bolts.
thanks
Jorge
« Reply #3 on: March 15, 2007, 07:32:51 AM »
hi,yes,a torque wrench its called,com in different loads,so make sure you get one with the torque band you need.
because the bis is so awkward to get too,i reckon that was skipped at first service etc you know?.along with hhe oil filter........
chatting to a guy the other day who used to be involved with the service of our once big hire car fleets,he said there were bis and aircooled 126's for hire,neither used to get oil filter done.he said they dont have one!.
made me wonder if any of you guys have jersey cars?
jpimpao
« Reply #4 on: March 15, 2007, 11:34:23 AM »
It is quite dificult to clean the oil filter, i did attempted to take it out one of this days on my own , I had the back bumper screws undone but i couldn`t take the big one with the spring out and I gave up.
I have to try it again with more time.
Thanks for your help
Jorge
« Reply #5 on: March 15, 2007, 06:54:16 PM »
Thanks for your replies!  If my headgasket does go and I get that nice frothy oil and water stuff; when I drain the engine to change the gasket do I have to clean out the engine first, like flush it through to get rid of the sludge?
« Reply #6 on: March 20, 2007, 03:04:39 PM »
I drive my BIS like a lunatic and it never overheats and hasn't...touch wood trashed a head gasket.
I get the feeling in this weather that it doesn't have a thermostat installed.
The way I see it is if it ain't broke I ain't gonna touch it so I simply warm her up a little, have a ciggy, observe the blonde neigbour in her kitchen etc. before heading-off.
« Reply #7 on: March 20, 2007, 05:39:01 PM »
:lol:  :lol:
yes i think youre right darrel, its so important to get engine nice and warm before you thrash it, alot of people just turn ignition on and off they go do 60. You need ot get the oil warmed up as well as the water, as the metals have to expand (especialy if its an alloy engine) Apparently alot of engine wear is caused from start up.
regards
