Author Topic: hi newbie requires info  (Read 7922 times)
zola67
Re: hi newbie requires info
« Reply #15 on: August 03, 2015, 09:51:58 PM »
hi,
been driving my 126 bis to work and back, got lots of looks and people asking about the car
passed mot but think I need to get brakes looked at as having trouble stopping
anyone any suggestions, I know the fiat 126 shares the same brakes that the Rolls Royce Phamtom has - it may just be me use to driving a larger estate car with very sharp brakes
great to drive though my uncle has had his fiat 126 for over 40 yrs in Italy and loves it to bits - he wouldn't change it for any other car he told me - hopefully I will have mine for that long too!
zola67
« Reply #16 on: August 05, 2015, 09:21:57 PM »
hi,
need brakes looking at
just drove home tonight had to use hand brake to stop
thankfully got back
drcdb15
« Reply #17 on: August 05, 2015, 10:14:26 PM »
Not sure if you're asking for advice, or simply telling us the on-going state of your car...
What were the advisories on the MoT?
If the brakes are suddenly getting worse over just 24hours it sounds like some leak somewhere that started small but is rapidly getting massive - so suspect a split hose somewhere. But in any event check the reservoir first and see if all/most of the fluid has gone.
If it has, then a quick check around the back of each brake back plate should show you where the leak is. If all seem OK, then you need to start following the brake lines from the master cylinder down to each wheel. It could be a corroded or burst/split brake pipe, or might be a union nut coming loose at one of the connectors or junctions.
Also check around the master cylinder itself, to be sure that hasn't cracked or got a loose connection.
Kitchen towel is good for showing up any leak, just reach under the car and press a sheet up against the back of the brake plate. The fluid should be freshly out of the system, hence clean and clear. Anything dirty with lots of grit and grot in it will have been there some time so is probably not your brakes leak.
zola67
« Reply #18 on: August 11, 2015, 09:33:21 AM »
hi,
thanks for the advice
I am not the most mechanically minded person so I think next chance I get I am going to pop it round the corner for the mechanic to look at
thanks
