Author Topic: VIN plate location  (Read 2387 times)
VIN plate location
« on: July 06, 2015, 05:31:20 PM »
Can someone help and tell me the exact location of the VIN plate on a 1981 126. I thought the location had been hidden by a modern radio but having removed it I can't even find any holes where the plate might have mounted.
Bar Vitelli
Re: VIN plate location
« Reply #1 on: July 06, 2015, 06:47:53 PM »
Hi Rusty, it's normally either on the top of the wheel arch or on the upper bit of the inner front panel near where the details are embedded in the bodywork.  I can ping you some pictures of where it is on mine if it helps.
Every cloud has one...
« Reply #2 on: July 06, 2015, 09:22:14 PM »
Hi BV, any pic would be a help even if it just eliminates where it is not.  :)
DeVilleChris
    • Club 126 UK
« Reply #3 on: July 06, 2015, 10:37:46 PM »
I've sent you an email Dave :)
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
« Reply #4 on: July 07, 2015, 09:09:12 PM »
Cheers Chris. The radio had been fitted close to the location but with your photo I found the original holes covered by small bits of tape but sadly the vin plate is missing  :(
Bar Vitelli
« Reply #5 on: July 07, 2015, 09:37:16 PM »
You can but replacement VIN plates if you need them, Rusty, there easy enough to get off of eBay. Is it something else you needed the VIN plate for?
« Reply #6 on: July 10, 2015, 05:55:12 AM »
No I just wanted a VIN plate and wondered if it might have been relocated  :)
