Author Topic: Engine swap  (Read 2058 times)
Da Londo
    • Fiat 126 blog
Engine swap
« on: May 15, 2015, 11:42:40 PM »
I'm not really fond of the whole engine swap thing but something just crossed my mind today.
As rotary engines are very compact, would there be a chance there is one that would fit?
« Last Edit: May 16, 2015, 07:27:40 PM by Da Londo »
Re: Engine swap
« Reply #1 on: May 16, 2015, 09:03:09 AM »
I would've thought so and so long as the rotation is the correct way you may get away with using the 126 gearbox. Not sure if you'll get on in a BIS though
Re: Engine swap
« Reply #2 on: May 18, 2015, 09:01:23 PM »
At Retro Rides a couple of years ago we were discussing this as there was a Triumph Herald with this conversion, Smallcox who built his wide bodied turbo reckoned it would fit into the aircooled engine bay without a problem and would be an easier option to create a great sleeper,
The only problem you would have is that you would have to fabricate a new bulkhead, but you should also check what the regulations are in Belgium for that type of modification ;)
Re: Engine swap
« Reply #3 on: July 30, 2015, 04:13:32 PM »
Somehow I dont think gearboxes would last very long and fuel consuption of rotaries is rubbish.
Should fit though, we measured it.
