Author Topic: Which way Around? Part 2  (Read 1641 times)
Bambino126
« on: April 30, 2015, 03:02:32 PM »
When I pulled off my fuel hoses, to remove the engine, these little brass stub pipes came clean out of the fuel pump.
I quickly tapped them back in without thinking much about it, but I'm now noticing that they have a very different bore, so they are obviously not interchangeable.
Have I put the right pipe into the right hole, or done it the wrong way around?
Thanks again!
dadandlad
Re: Which way Around? Part 2
« Reply #1 on: April 30, 2015, 04:24:52 PM »
Yes that is the correct way round
Bambino126
« Reply #2 on: April 30, 2015, 08:13:28 PM »
Thank you!!  ;D
