Author Topic: 2 Speed heater  (Read 2377 times)
mintex
2 Speed heater
« on: April 30, 2015, 12:28:26 PM »
Hi all.
Anyone any one good with electrics please :)
The heater on our bis only works on one speed, when you push the switch away from you and i think that's the fastest one?
If i pull it towards me i get nothing.
Are the electrics on the fiat a switchable earth system? Is there an easy way to test if its the switch, blower of the wires in between please  :)
Dave
dadandlad
Re: 2 Speed heater
« Reply #1 on: April 30, 2015, 04:58:46 PM »
If you remove the switches, on the back of the switch you have three connections
MB supply from fuse
Z supply to fan motor 2nd speed
B supply to fan motor 1st speed
You obviously have a feed going in on MB
See if you have a feed coming out on B when switch operated if not it is your switch
If you have a feed you then need to check to see if you have a feed at the motor, if not you have a broken wire between switch and fan
If you have a feed at the motor it is probably the resistor that has gone
On my Bis there is a resistor mounted at the back of the front panel hidden by the spare wheel I have a sneaky feeling this could be the heater motor resistor, but only having it a few weeks I haven't had chance to investigate
Easy enough job to do but hard to describe but hope it helps
« Last Edit: April 30, 2015, 05:03:48 PM by dadandlad »
Re: 2 Speed heater
« Reply #2 on: April 30, 2015, 06:55:01 PM »
I get its the switch. Mine fell apart inside so the contacts wouldn't touch
mintex
Re: 2 Speed heater
« Reply #3 on: April 30, 2015, 07:16:05 PM »
Ok thanks guys, i will look into it and post back the results  :good:
Dave
mintex
Re: 2 Speed heater
« Reply #4 on: April 30, 2015, 09:25:00 PM »
Cheers guys, its working now  :D
Turned out to be a bad connection on the fan motor :yahoo:
Dave
andyzeetec
  • 126 BIS
Re: 2 Speed heater
« Reply #5 on: April 30, 2015, 10:08:53 PM »
The 3 spring thing is a resistor that controls the dip/main beam on your head lights.  :)
MB supply from fuse
dadandlad
Re: 2 Speed heater
« Reply #6 on: April 30, 2015, 10:17:27 PM »
Quote
Cheers  :)
