Fiat 126 Chat
Wiring advice needed
Pages: [
Topic: Wiring advice needed (Read 2675 times)
Kent126
Closer every day to getting on the road....
on:
February 03, 2015, 10:43:20 PM »
Hi guys,
Is there anyone on here who is a wiring guru? I am tidying up my wiring loom as part of my restoration, with the addition of some extra things.
I'm adding an air horn which I know requires a relay, that is fairly straight forward but has anyone installed one? Is the battery and wiring strong enough to cope?
Also has anyone installed new H4 bulb conversions? I know you can get the extension cables but do you need to update the fuse box or uprate the wiring? I've heard that the H4 type bulbs can burn out the wiring loom.
I don't mind upgrading stuff to cope with modern demands if required.
Any advice or help appreciated.
Tom
Sent from my iPhone using Tapatalk.
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Administrator
Re: Wiring advice needed
Reply #1 on:
February 03, 2015, 11:10:56 PM »
You need to put two relays in, small fuse box or inline fuse for the headlight bulbs and another for the air horns, Plenty on Ebay
Pete.
il cavallo piccolo
Subscribers
Reply #2 on:
February 04, 2015, 11:59:46 AM »
My very first 126 had air horns and they worked no problem
the only thing I had against them is that sometimes there was a 1 or 2 second delay from pressing the horn button to them from actually making a noise as the compressor built up with air lol
GET SOCIALBLE. Instagram me on _gadge_
Kent126
Reply #3 on:
March 05, 2015, 02:02:52 AM »
Thanks guys.
Pete, what amp fuse would I need?
ronb1967
Subscribers
Member
Reply #4 on:
March 07, 2015, 11:12:25 PM »
Use standard 4 pin relay,,,, just look on youtube under HOW TO WIRE A 4 PIN RELAY
Example 1 Bulb is 60 watts
car is 12 volts
so 1 x 60 watts divided by 12 volts = 5 amps 60/12=5
2 x 60w = 120 w divided by 12 volts = 10 amp
Kent126
Reply #5 on:
March 11, 2015, 05:09:41 PM »
Ok that makes sense! Thanks! 😀
Pages: [
Fiat 126 Chat
