Author Topic: 126p Bis "up" From Turkey :)  (Read 11562 times)
sahin261
Re: 126p Bis "up" restoration.
« Reply #15 on: April 22, 2015, 07:42:02 PM »
Hello, I did a lot of things. soon I will share with you.
Also good news: I learned: How to convert 4 cylinder engine's tachometer for 2 cylinder  :)
mintex
« Reply #16 on: April 22, 2015, 10:42:27 PM »
Just looked though your thread, some good work  :)
Did you get the tachometer working for the bis model or the air cooled as i want to fit one to ours  :)
« Last Edit: April 27, 2015, 09:52:39 PM by mintex »
Dave
sahin261
« Reply #17 on: May 31, 2015, 07:57:03 PM »
Hello tachometer works so good.
As you know we are using 4cyl engine's tachometer. But our engine 2cyl, so it shows half. When our engine makes 4000rpm, tachometer will show 2000rpm. Just you need to add extra capacitor. You need to make 220 NF --> 440NF
this work making x2 result.
I mean: normally 2000rpm after capacitor shows 4000rpm. :) ı hope i explained good.
I did also a video, with pictures about tachometer.
https://www.youtube.com/watch?v=5VgMqtGOi7w
« Last Edit: May 31, 2015, 08:03:15 PM by sahin261 »
sahin261
« Reply #18 on: May 31, 2015, 08:12:07 PM »
from 126 el, gauges. + Cinquecento Temperature Gauge. It fit so good except temparature. If you want elx's gagues you must also buy elx's speedometer cable.Because Bis speedometer cable is not fitting with elx. This is the same with CC sporting gauges :)
as you can see difference, (left bis, right elx)
Everything was good but until engine get hot. Cinquecento temparature gauge is showing ~12 *C more. It is dangerous. Like overheating.
Neverming orginial is better  :D
sahin261
« Reply #19 on: May 31, 2015, 08:22:17 PM »
some clean  :P
sahin261
Re: 126p Bis "up" From Turkey :)
« Reply #20 on: June 11, 2015, 04:32:42 PM »
Central lock system  8)
https://youtu.be/kOiGXhWnQWs
sahin261
« Reply #21 on: December 20, 2015, 10:51:45 PM »
Hello everyone. One of big modification on engine:
Nanoplex ignition. uuum where is distribitor?  ;D
[youtube]watch?v=Xc0Lr0HPytA&feature=youtu.be[/youtube]
