Author Topic: Rusty cylinders  (Read 6584 times)
Da Londo
    • Fiat 126 blog
Re: Rusty cylinders
« Reply #15 on: January 19, 2015, 03:09:25 PM »
So that woild be a light sanding with 150 grit? I thought that was the worst one could be doing to the bores?
gammakeith
Re: Rusty cylinders
« Reply #16 on: January 19, 2015, 04:49:32 PM »
Only if you don't clean them afterwards  ;D  Apparently, if rings are proving reluctant to seal after an engine rebuild then introducing powdered Vim via the air intake can work  :o  I've never tried it myself as the cheap glaze buster I got from Machine Mart has always worked fine (as did the manual method before that).
Keith
