Author Topic: Starting issue  (Read 4929 times)
cider
Starting issue
« on: January 04, 2015, 09:45:50 PM »
I`m having issues starting our bis seem I have to crank it over for such a long time
to get it to fire that it almost flats the battery, :( but when it catches it runs fine.
What I`ve done is to replace the fuel lines and fitted a electric pump
as to make sure fuel is getting to the carb
And still will not fire/start " I`m sure its a land rover in disguise!! wont start, rusty and leaks oil  :o"
Any pointers please ;D
Pete
Re: Starting issue
« Reply #1 on: January 05, 2015, 08:01:09 AM »
If I had to guess I'd say your battery is on its way out- what sort of voltage is you battery showing?
Clancy_Ryan
Re: Starting issue
« Reply #2 on: January 05, 2015, 12:26:57 PM »
Definitely looks like battery, I've had the same issue and once I've replaced it with a new one, never had ane problems again.
cider
Re: Starting issue
« Reply #3 on: January 05, 2015, 01:58:28 PM »
Just took the battery out and stuck it on a charger so will see if it will start
When i brought the car in march I was informed it had a new battery fitted  ??? might need to
get it tested :(
What sort of cold crank amps should the battery be
Pete
Re: Starting issue
« Reply #4 on: January 05, 2015, 04:19:38 PM »
cider
Re: Starting issue
« Reply #5 on: January 10, 2015, 10:15:36 PM »
Well we brought a new battery and............
We still have no go :(
There`s fuel getting to the carb
Getting a spark at the plugs,,, spark plugs are clean
New plug leads fitted
Any Ideas to what the contact point gap should be please or point me in the direction where to
go next
Thank you
pete
Re: Starting issue
« Reply #6 on: January 11, 2015, 12:26:50 AM »
The points are set at 0.40mm also check the ignition timing once you have set the points ;)
cider
Re: Starting issue
« Reply #7 on: January 11, 2015, 06:50:54 PM »
Today I`ve re-set the points to 0.40mm :) when the engine is turning over via the starter
the points arced like someone welding :o ,so when I put a little pressure on the points it came to life with no arcing
Removed finger the engine died "There`s light at the end of the tunnel :D"
Points on their way out maybe ??
Pete
Da Londo
    • Fiat 126 blog
Re: Starting issue
« Reply #8 on: January 11, 2015, 07:23:10 PM »
Replace points and condenser and set timing.
cider
Re: Starting issue
« Reply #9 on: January 11, 2015, 08:46:59 PM »
Thank you all for the help  :D
Would someone have a link to how to re set the point timing please
Thank you
Pete
Re: Starting issue
« Reply #10 on: January 11, 2015, 09:32:12 PM »
Here's an easy way to set timing.
Set the point gap. Put the car into 2nd gear and rock the car until the little Mark on the pulley lines up with the first of the 3 pointers on the engine casing. You now have 10 degrees before TDC (this is where the piston needs to be). Next loosen the distributor bolt so it can turn freely by hand. Turn the distributor so that the points are just about to open - this can be done very accurately by turning the ignition on an touching one side of the points with a test light. When the points are closed the light will come on, when they open the light turns off so just as it goes off is the point the points have just opened. Once this has happened lock the distributor bolt. Timing is now set :)
The arcing that you mention is a knackered condenser but I would advise replacing the points aswell as the arcing may have pitted them
cider
Re: Starting issue
« Reply #11 on: January 11, 2015, 10:04:01 PM »
Spot on Gadge Just what I`m looking for Cheers :D
Re: Starting issue
« Reply #12 on: January 12, 2015, 07:17:17 AM »
No problem bud :)
cider
Re: Starting issue
« Reply #13 on: January 12, 2015, 10:13:59 PM »
A bit of a update today; points and condenser ordered "I live next door to an auto parts store :D"
Sadly not an stocked item  ::). I was talking my issues with me old man then he walked off to his
shed and came back with a old square bisto tin full of old keys car bits etc.Yep theres a old Leyland
packet with a condenser, after fudging and faking it into place me bis fired up on the first turn ;D
and drove as if there was a turbo in there :D
The love is back
Re: Starting issue
« Reply #14 on: January 12, 2015, 11:48:21 PM »
Perhaps your 126 is a Land Rover in disguise, that's if it's running better with a British Leyland part  ;)
I am glad that you have solved out your problem.
