Author Topic: Well, it was inevitable! Here is my 126!  (Read 33214 times)
dombooth
Re: Well, it was inevitable! Here is my 126!
« Reply #30 on: December 13, 2014, 11:24:28 AM »
So... Still got some wiring issues to sort, but that's going to take some time to fathom out!!
dombooth
« Reply #31 on: January 12, 2015, 11:30:48 PM »
Apologies for no update in a while.........
But anyway, after countless hours continuity checking wiring here there and everywhere, the electrical issue is fixed! One loose connection from the positive feed to the ignition..
So once that was sorted I've started to strip the car down.
Most parts are in the garage loft...
A few random pics...
... To be continued
« Last Edit: January 12, 2015, 11:56:06 PM by dombooth »
« Reply #32 on: January 13, 2015, 07:11:57 AM »
Good work Dom :D
dombooth
« Reply #33 on: January 13, 2015, 10:30:08 AM »
Good work Dom :D
Cheers Gadge. :)
There is more to update, that you know about, but I'll do that when I've got more time!
dombooth
« Reply #34 on: January 25, 2015, 10:50:56 PM »
Righty ho........
The next stage was to remove the windscreen and rear window. (Joy!)
Now I'd rear most threads on here about the best method of removing the windows, asked Gadge for advice etc.  So I set an evening to get it out, and stuck to it.  I pushed and shoved and it didn't come out easily.  I repair laptops so have about 50 blank credit cards I use, I found that pushing these inbetween the rubber and the body inside the car would loosen up the rubber nicely.  So I put these all the way along the top and sides. No pics sadly
But, I do have a video for you all to laugh at:
(skip to 11:30 to just see it pop out)
https://www.youtube.com/watch?v=aJICthhqN6U
And out it pops in one piece! In hindsight, I should've asked my dad to stand infront of it just in case.
Here's the rust on the bottom of the windscreen:
Similarly I used the same card method with the rear window (and got my dad to stand and catch it!)
Although to get my feet on the rear window, I had my lower back on the back seat, head in the passenger footwell, feet on the glass, and hands on the dashboard.  Interesting position for a car!  :o  :D
And here's the rust on the rear window:
dombooth
« Reply #35 on: January 25, 2015, 11:12:52 PM »
So, I continued stripping down...
Got some of this recommended by Gadge:
And after peeling back the carpets/seats/etc I found this...
Hmm, bit of plastic stuck on (still sticky), after pulling it off it revealed this:
Not too bad though, just wants to Kurust on it, and a little plate to tidy it up. Then I'll fill the sill with cavity seal or something similar.
dombooth
« Reply #36 on: January 25, 2015, 11:30:27 PM »
And today saw a friendly face in the form of Gadge coming up to give me a hand with engine removal.  I seriously can't thank him enough, there's no way I'd have managed on my own!
We started cracking on with the rusty windows with a file and Kurust (no pics though).
Then got cracking on the engine...
We got the trolley jack under the engine, and put a rope around the gearbox and over the steel for me to hold as Gadge took off the last of the gearbox mounting bolts off (pretty sure this is what the previous owners used it for too..).
A quick peek inside the gearbox looks good. :)
Out on the floor:
Engine bay:
When the engine is out, make sure the fuel pipes are up, not left dangling or fuel will pour out if you jack up the front... Guess how I found that out?  ::)
After a dash to find an empty bottle, I caught the rest and mopped up the spilt fluid.
Waste coolant that drained out:
As I left it for the night, looking like a 126 4x4:
Gearbox mounts are buggered, and my "to buy" list is now 3 times as long as yesterday!! :)
dombooth
« Reply #37 on: February 16, 2015, 11:17:03 PM »
Bare in mind I'm no film maker... But here's the underside:
https://www.youtube.com/watch?v=EhQxnqt8dIU
sunriser81
« Reply #38 on: February 17, 2015, 08:51:46 AM »
Hi its nice little BIS looks very solid, good luck with restoration  :)
dombooth
« Reply #39 on: February 17, 2015, 08:54:08 AM »
Thanks. :)
judson-126
« Reply #40 on: February 17, 2015, 07:02:55 PM »
Looking nice!
dombooth
« Reply #41 on: February 17, 2015, 07:45:55 PM »
Looking nice!
Cheers mate. :)
Did you do anything to the underside whilst you had it?
judson-126
« Reply #42 on: February 17, 2015, 10:50:59 PM »
nope whys that
dombooth
« Reply #43 on: February 18, 2015, 12:02:31 AM »
Just wondered as some of it looks pretty fresh
judson-126
« Reply #44 on: February 18, 2015, 07:46:54 PM »
Thd guy before me done a few bits & pieces i think mate, fibreglassed the drain plug holes etc to avoid any water sitting in the floorpan & rotting the jacking points out as there prone to go there going by my old old one which i had to weld up, the bit of plastic covering the sill hole was another precaution to avoid water getting into the sill, looks like its done the job! Happy to see the minority of rust, cant believe its been stripped down though lol good luck & hope it gets done right! ;D
