Author Topic: Dash Air Vent  (Read 1721 times)
cider
Dash Air Vent
« on: November 06, 2014, 03:04:29 PM »
I`m in the middle of removing the dash cover so to do a bit of welding on the screen panel
But Just can`t see how to remove the centre air vent :(
Pete
Re: Dash Air Vent
« Reply #1 on: November 06, 2014, 04:22:51 PM »
It has 4 little pegs molded into it so when it's pushed in it clips into the metal frame work. To remove it without breaking it I squeezed it from the inside of the luggage compartment an pushed it into the cabin. You may have to remove some of the heater system to get at it though
cider
Re: Dash Air Vent
« Reply #2 on: November 06, 2014, 10:19:21 PM »
Thank you for your reply I`ll give it ago :) :)
Pete
cider
Re: Dash Air Vent
« Reply #3 on: November 07, 2014, 05:35:19 PM »
What a pig n a poke of a job to remove from luggage compartment, well I`ve removed it ;D
only to find that there`s four tabs inside the vent "one on each corner" to able you to remove the vent from inside the car  :o ::) ;D
Pete
Bolek
Re: Dash Air Vent
« Reply #4 on: November 09, 2014, 10:37:35 AM »
I am always a big fan of the "crowbar" method ;)
