Author Topic: Oil pressure sensor problem  (Read 2597 times)
« on: October 28, 2014, 03:41:01 PM »
I think I may have a duff pressure sensor. The light doesn't come on when you switch the ignition on so its either a knackerd switch or simply a dash bulb so is there anyway I can test the sensor first before I rip the dash out?
Clancy_Ryan
Re: Oil pressure sensor problem
« Reply #1 on: October 28, 2014, 03:48:09 PM »
Sorry, wrong thread. :(
« Last Edit: October 28, 2014, 03:51:18 PM by Clancy_Ryan »
gammakeith
« Reply #2 on: October 28, 2014, 04:47:14 PM »
If you unplug the connector at oil pressure switch and earth it the warning light should go on.  The oil pressure switch earths the bulb.  Thus, if no light (or voltage at the connector) then bulb is most likely dead.
Keith
« Reply #3 on: October 28, 2014, 06:18:07 PM »
Excellent thanks very much I'll give it a whirl :)
Piotross
« Reply #4 on: October 28, 2014, 06:56:40 PM »
I found one new Magnetti Marelli, it cost 100 pounds, to expensive ?
Xylaquin
« Reply #5 on: August 24, 2015, 12:10:30 AM »
Sorry to resurrect this thread but thought it better than starting a new (potentially duplicate) one.
Is the oil light meant to come on when you turn on the ignition? Mine has never done that until today. Once I start the engine it goes out, and never comes on again.
I just drove home after a 40 minute cruise along the motorway, no warning lights, everything fine. When I parked the car I turned off the engine and then immediately turned the ignition back on, and lo! the oil light came on. Is that right?
mintex
« Reply #6 on: August 24, 2015, 12:18:53 AM »
Yes, It should come on when you turn the ignition on  but go out once its running  :)
« Last Edit: August 24, 2015, 10:51:56 AM by mintex »
Dave
Xylaquin
« Reply #7 on: August 24, 2015, 01:02:45 AM »
Ah that's good. Although now I wonder why it suddenly started 'working' today.
dadandlad
« Reply #8 on: August 25, 2015, 10:02:55 AM »
Have a look at the wiring where it connects to the terminal that goes onto the oil pressure switch mine had a break right on the point where the terminal is crimped on
